I have a grid that could contain upwards of a million records or more (yes, a bit unconventional, but the XamGrid does an outstanding job with this many records)
I have the filter settings set to <
ig:FilteringSettings AllowFiltering="FilterMenu" />
I would like to not show the "Select All" checkbox or populate the listbox (a million entries in the filter listbox is pretty much useless) and only show the "Clear Filters" and "Custom Filters" in the ColumnFilterDialogControl
I did search the forums, and the closest I could get is this example for the "Custom Filters"http://forums.infragistics.com/forums/p/50715/266360.aspx
Thank you!
Hello Terry,
I have been looking through your issue and I created a sample project for you. Basically I copied the default style for the FilterSelectionControl and I remove the ListBox and the CheckBox controls, which you don’t want to display. I recommend you do so in the future when you want to retemplate a control in order not to lose functionlaity. The default styles are installed here: C:\Program Files (x86)\Infragistics\NetAdvantage 2011.1\Silverlight\DefaultStyles by default. Please let me know if you need further clarifications on this matter.
Thank you Stefan for your assistance on this!Perfect!I copied out the relevant sections from generic.xaml - works perfectly
Sometimes a person just needs a nudge...
Hello again,
Thank you for your feedback. I believe other community users can benefit from this thread as well. If you have any other questions do not hesitate to ask.
Thanks again.
