Xamformulaeditor is showing formula dialog as disabled if we open it from a normal silvelight chid window
Is a the Target property of the XamFormulaEditor set to an object that is registered with a XamCalculationManager?
Yes we set it target prperty but from infragistics dialog box it is working fine with the normal silverlight childwindow only has this problem
The same bug is coming to me also, even if we set the target property of formula editor if we call it in normal silverlight childwindow the formula editor dialog is disabled even the close button is also disabled
I looked into this issue today and was able to reproduce it and find a fix as well. As long as the fix passes our testing process, it should be available in the next SR. Unfortunately, I was not able to find a workaround for you to use for now.
