Even if we set the target property of formula editor if we call it in normal silverlight childwindow the formula editor dialog is disabled the close button of the formula editor is also disabled
I was looking into your issue and in order to reproduce it I have created a sample project which I have attached to this email. I have placed in a ChildWindow a XamFormulaEditor and a TextBox which is binded to a XamCalculationManager, and the XamFormulaEditor appears in enabled state as expected.
I can suggest double checking the binding to the particular property that you are using.
Please let me know if you are still able to reproduce the described behavior using my sample application.
Sincerely,
Ekaterina
Developer Support Engineer
Infragistics Inc.
www.infragistics.com/support
Hello
i am calling the childwindow in the button click of another page.i use the same solution you send but i add one more page and call the child window in the button click.Now the formulaeditor is in disabled state.Please check. My code is like
using
System.Windows;
System.Windows.Controls;
System.Windows.Documents;
System.Windows.Input;
System.Windows.Media;
System.Windows.Media.Animation;
System.Windows.Shapes;
System.Windows.Navigation;
namespace
xamFrmlaEdtrDiabledInChildWIndow {
Page
Page1() { InitializeComponent(); }
// Executes when the user navigates to this page.
e) {
Thank you for your feedback.
In order to furder investigate the issue I have recreated your scenario but I did not manage to get the same behaviour. I added an extra page with a button which calls the childWindow contol and the xamFormulaEditor appears in enabled state as expected.
Would you please, if possible, provide me with a sample application which demonstrtaes the issue in order to be able to provide you with more accurate assistance on the matter? Sincerely,EkaterinaDeveloper Support EngineerInfragistics Inc.www.infragistics.com/support
I am attaching the screen shots i think this will help you.
My full code also attached please look into this issue as soon as possible
Hello, I have logged this behavior with our developers in our tracking system, with an issue ID of 98781. I have also created a support ticket on your behalf with number CAS-80752-4FZQVT in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download. Sincerely, Ekaterina Developer Support Engineer Infragistics, Inc. www.infragistics.com/support
Infragistics, Inc.
