50
How to extend WebAsyncRefreshPanel's timeout
I try put this code Javascript when the WebAsyncRefreshPanel Initialize to change the Timeout but isn't work, I can only change the Timeout from 20 sec to 30 sec but no more.
        function WebAsyncRefreshPanel1_InitializePanel(oPanel) {
            ig_shared.getCBManager()._timeLimit = 60000;
    </script>
I try put it this code directly but the result is the same. Can Anybody help me?
Thanks's in advance for your help.
  • 37874
    Hello mllovera,
    I have tested your scenario with NetAdvantage 11.1 but I was not able to reproduce the behavior you have described and setting the _timeout fires the _timeOut function of the CBManager as expected. In order to be able to provide more insight I would need to know your exact product version. Please note that the WebAsyncRefreshPanel has been retired. A detailed list of the retired controls and their respective replacements is available at: http://blogs.infragistics.com/blogs/taz_abdeali/archive/2011/11/17/asp-net-product-changes-in-2011-volume-2.aspx.
    Please let me know if you have any other questions.
  • 37874
    Hello mllovera,
    If you still need assistance on the matter please feel free to contact me.
  • 24497
    Hi mllovera,
    I think that server has some logic which limits timeout to 30 seconds. The ig_callBackManager does not have specific limit for its _timeLimit member.
    I suggest you to test a page which contains only following codes.
    After a button click and waiting for 50 seconds it should produce output (yellow top DIV) of "response:50004".
     If it will work as expected, then you should investigate logic of your server for possible timeouts outside of WARP.
    aspx:
    var time = new Date().getTime();
    function Warp1_InitializePanel(oPanel){
     ig_shared.getCBManager()._timeLimit = 70000;
    function Warp1_RefreshRequest(oPanel,oEvent,id){
    function Warp1_RefreshResponse(oPanel,oEvent,id){
     _bug4('response:' + (new Date().getTime() - time));
    </script>
    <igmisc:WebAsyncRefreshPanel ID="Warp1" runat="server" InitializePanel="Warp1_InitializePanel" RefreshRequest="Warp1_RefreshRequest" RefreshResponse="Warp1_RefreshResponse">
       <asp:Button ID="Button1" runat="server" Text="Button" />
    </igmisc:WebAsyncRefreshPanel>
    aspx.cs
    protected void Page_Load(object sender, EventArgs e)
       if(this.IsPostBack)
          System.Threading.Thread.Sleep(50000);
