I've a ultrawebgrid used in my application. Is there any black theme available for this grid? If yes, can you please provide me the link to download it?
If not, any pointers to change the theme to black.
Thanks in adv.
Any update on this .. Been waiting for a response.
-Sagar
so essentially with the preset option, we could change look and feel of the ultrawebgrid, right?
Can you elaborate more on preset, like i dont have any extra or pre-existing preset handy that i'll apply to the grid..
the newsPaper.xml file preset option you talked about, the area where rows are visible, it is white in color and the data in black. I want the other way round, text should be white and blackground should be black.
Do you have any existing preset that has this kinda of theme ? Like infragistics igGrid (which is client side grid).
Plz let me know, i need it badly.
thx,
Sagar
Hello Sagar,
You can copy the "newsPaper" XML file (for backup), then open it in any editor and change the colors that you need to be different.
"HeaderStyleDefault" section for the header and "RowStyleDefault" section for the grid rows.
You can change the other styles as well (their names are similar to the parts of the grid they apply to), save the file, reload it and you should see the changes in your grid.
Got the filter icon on the header, had to add the setting in the preset xml.
Secondly, is there any way using the preset xml methodology to add an image as background to the header ?
