Hi All,
I have an application running on ASP.NET 1.1 framework and using Infragistics Net Advantage 2005 Vol 3.
When I open the site on IE 10, few frames using Infragistics modules don't load. The site works fine on all other latest Grade A browsers.
I see the error,
"Input string was not in a correct format"
Stack trace:
[FormatException: Input string was not in a correct format.]
System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) +0
Infragistics.WebUI.UltraWebListbar.UltraWebListbar.getRenderer() +381
Infragistics.WebUI.UltraWebListbar.UltraWebListbar.PreRenderLBar(Object sender, EventArgs e) +18
System.Web.UI.Control.OnPreRender(EventArgs e) +67
System.Web.UI.Control.PreRenderRecursiveInternal() +62
System.Web.UI.Control.PreRenderRecursiveInternal() +125
System.Web.UI.Page.ProcessRequestMain() +1499
Please let me know
- If this is an issue of browser compatibility.
- If there are any hotfixes available to resolve this issue.
Thanks and Regards,
Karthik
Karthik,
NetAdvantage 2012 Volume 2 is the first volume of NetAdvantage that supports IE10. Note that the exception that you are getting is with the UltraWebListBar and that control was retired in 2011 and is no longer included in the NetAdvantage toolset. There are more details on the retired controls in the ASP.NET product changes blog post.
If you wish to upgrade to the latest version of NetAdvantage that contained the UltraWebListBar to see if it has the same issues you could upgrade to NetAdvantage 2011 Volume 1 which is available on the archived downloads page. Note that while this is supported in IE9, it was not tested in IE10 and is no longer maintained.
If you do need support for IE10, Chrome, or Safari, then it is recommended that you replace the retired controls with either the ASP.NET AJAX controls. The suggested replacement controls are also in the ASP.NET product changes blog post.
Let me know if you have any questions with this matter.
Hi Alan,
I downloaded and installed the trial version of the NetAdvantage 2011 Volume 1.
When I am trying to add the reference Infragistics2.WebUI.UltraWebListbar.v11.1.dll to my VB.Net 1.1. project, I am getting the error
"This is not a valid assembly or COM component"
I tried running the tlbimp.exe <DLL> command. I got the "Not a valid type library" message.
Please let me know how to proceed.
NetAdvantage for ASP.NET 2011 Volume 1 requires .NET Framework 2.0 so you would need to upgrade to a later version of the .NET Framework.
We are planning to migrate the application in 1.1 framework to 4.0
Like I have mentioned earlier, our application throws an error w.r.t UltraWebListBar control when opened on Windows 8/IE 10
Please let us know which is the latest Infragistics package that is IE10/Windows 8 compliant..
NetAdvantage 2012 Volume 2 is the first volume that supports IE10. Note that the UltraWebListBar was retired and was last included in NetAdvantage 2011 Volume 1.
