45
Reusable xamcontextmenu user control
Hello.  I am trying to make a context menu a user control so that it can be reused in multiple areas.  The question I have is how should I assign the xamcontextmenu to the control in the xaml?  The way it is now is a context menu within a context menu, I want to assign the context menu directly to the user control.
User Control I want to reuse:
<Grid Name="cmnuGrid">
        <ig:XamContextMenu Opacity="1" Name="cmnuChart" Placement="MouseClick" BorderThickness="1" FontSize="12" Opening="evhContextMenu_Opening" Background="Cornsilk">
            <ig:XamContextMenu.Style>
                <Style TargetType="ig:XamContextMenu">
                    <Setter Property="Background" Value="Cornsilk"/>
                </Style>
            </ig:XamContextMenu.Style>
            <ig:XamMenuItem Name="xmiChartOptions" Header="{Binding Path=Strings.Options, Source={StaticResource ViewResources}}"
                    Height="30" Background="Cornsilk">
                <ig:XamMenuItem.Icon>
                </ig:XamMenuItem.Icon>
                <ig:XamMenuItem Name="xmiFitChart" Header="{Binding Path=Strings.FitChart, Source={StaticResource ViewResources}}"
                        Click="xmiFitChart_Click" Height="30" Background="Cornsilk"  >
                </ig:XamMenuItem>
            </ig:XamMenuItem>
            <ig:XamMenuItem Name="xmiExportChartMenu" Header="{Binding Path=Strings.ExportChart, Source={StaticResource ViewResources}}"
                <ig:XamMenuItem Name="xmiExportChart" Header="{Binding Path=Strings.ExportChart, Source={StaticResource ViewResources}}"
                                Height="30" Click="xmiExportChart_Click" >
                </ig:XamMenuItem>
                <ig:XamMenuItem Name="xmiExportOptionsChart" Header="{Binding Path=Strings.Options, Source={StaticResource ViewResources}}"
                                                            Click="xmiExportOptionsChart_Click" Height="30" Background="Cornsilk">
                </ig:XamMenuItem>
            </ig:XamMenuItem>
        </ig:XamContextMenu>
How I am assigning the context menu currently:
<ig:ContextMenuService.Manager >
                                                <ig:ContextMenuManager OpenMode="RightClick">
                                                    <ig:ContextMenuManager.ContextMenu >
                                                             <ig:XamContextMenu>
        <mycontrols:ucChartContextMenu Name="cmnuTrendChart" ehFitChart="xmiTrendChartFitChart_Click" ehExportChart="xmiExportTrendChart_Click" />
                                                    </ig:ContextMenuManager.ContextMenu>
                                                </ig:ContextMenuManager>
                                            </ig:ContextMenuService.Manager>
                                        </mycontrols:XamDataChartEx>
  • 34510
    Verified Answer
    Hi Panormitis,
    Instead of using a UserControl you should change it to a XamContextMenu.
    XAML:
    <ig:XamContextMenu x:Class="Application.Namespace.ReusableContextMenu"
        xmlns:ig="http://schemas.infragistics.com/xaml"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        Opacity="1" Placement="MouseClick" BorderThickness="1" FontSize="12"
            </Style>
        <ig:XamMenuItem Header="Item 1">
            <ig:XamMenuItem Header="Sub Item 1"/>
            <ig:XamMenuItem Header="Sub Item 2"/>
            <ig:XamMenuItem Header="Sub Item 3"/>
        </ig:XamMenuItem>
        <ig:XamMenuItem Header="Item 2"/>
    CS:
    public partial class ReusableContextMenu : XamContextMenu
        public ReusableContextMenu()
            InitializeComponent();
        private void evhContextMenu_Opening(object sender, OpeningEventArgs e)
    Then when you want to use this context menu:
                <local:ReusableContextMenu/>
