We have a XamWebChart - Bubble Chart with negative Co-ordinates and negative Radius not showing up properly upon rendering. A Blank grid comes up.
With positive values it works fine. Please check this issue and update.
Hello Pratik,
Thank you for your post!
I have been looking into your issue. What I can suggest is to use the XamDataChart control. More about the XamDataChart you can find from our documentation: http://help.infragistics.com/doc/Silverlight/2014.2/CLR4.0/?page=DataChart_DataChart.html.
Also, I have created a small sample application with the XamDataChart to test the functionality you have reported and I was not able to reproduce it. I am attaching the sample application I have been testing with for your reference.
Would you please modify the sample application with the data you are using? This way I would be able to further investigate this issue for you.
Thank you for the cooperation. Looking forward to hearing from you.
I am just checking if you have any further questions on this matter. Please do not hesitate to let me know if you do.
