In the filter drop down, we have large number of Members being displayed. We want to increase height and Width of the drop down control
Can you please provide me a way with the help of which we can increase height and width of the filter drop down control.
Please find attached image highlighting the drop down control whose height and width we want to increase.
Sachin
Thank you for your post.
I have been looking into your requirements and the image that you have attached. What I can suggest is to re-template the style named ExpandableFieldItemControlKey for popup window of filtering, it is located in the file named generic.shared.xaml. You can find the files with default styles on your computer in the following destination:
C:\Program Files (x86)\Infragistics\2014.2\WPF\DefaultStyles\XamPivotGrid
You can re-template the style for popup as set the width and height properties of grid with name OriginalPopupChild. I created a short sample application based on your scenario to show you how you can achieve the functionality you want.
Please let me know if you need from any further assistance on the matter.
Thanks for the reply. But I am using version 12.1 and not able to find ExpandableFieldItemControlKey in generic.xaml
Can you please help me with it.
I have been looking into it. As I mentioned in my last post the name of the file where you can find the template is generic.shared.xaml. The name of the style is ExpandableFieldItemControl. Destination where you can find the default styles is:
generic.xaml file referenced generic.shared.xaml and you should search the style in second one. Would you please double check if you search in correct file.
Please let me know of you need any further assistance on the matter.
I am just checking if there is anything else I can do for you.
Sorry for late response. The sample/solution which you have sent is of version 14.2. But we are using version 12.1.
Can you please provide some solution for the version which we are using.
Thanks & Regards,
