Is there a way to set where the advanced color picker pops up when you click the button? I have a color picker on the right side of the window, and when a user clicks on the advanced button, it pops up so that half of it is cut off at the edge of the window.
Hi RVassar,
The advanced color picker popup is calculating it's own position internally. What I found that you had to do was get the Popup and wait for it to open. Once it is opened you can set it's HorizontalOffset to move it left or right. This will override the calculated offset.
I attached a sample that demonstrates this. Let me know if you have any questions.
