Hey there,
I was wondering If I could get some help. I'm trying to access our own SharePoint environment on https://sharepoint.uvw.nl which is behind a Reversed Proxy setup with a form login, when I logon using Windows Authentification I receive a 302 error, which makes sense. When I change the verification method to Web Form based I still receive the 302. Any suggestions?
Thanks in advance.
Ciao!Thomas LefebureNL
Hello Thomas,
Thank you for your support request!
Are you able to access the same site via Chrome?
Would you mind sending screenshots of the login process?
Thanks in advance,
Thomas,
How are you?
Were you able to review my last message?
Looking forward to hearing from you,
Javier
Would you like to check with this particular document in case it’s that and let us know how it goes? Concrete Driveways
