I use Office 365 and sharepoint, and I am trying to connect to a Web App (Business contact tracker (MS Access) and getting the following error
Sharepoint Server Error
Shareplus detected a generic sharepoint error.
can you help please?
Hello Jason,
Could you please specify which version of SharePlus are you using?Is it a Pro or an Enterprise version?
We would also like to get some details on how do you plan to use both applications in connection.Looking forward to hearing from you.
Regards
Gonzalo T Associate Support Specialist Enterprise Mobility Infragistics, Inc.
I'm writing to you in order to check if you have further questions.
I will keep this case open for another three days while I wait for your response. If at that time you haven't responded, I will close this case as inactive. Please note that closed cases may be reopened within thirty days of closure.
Best regards.
SharePlus Lite is FREE and can be used to test connectivity to your site plus try SharePlus for browsing your content. Cockroaches exterminator
If you're having trouble keeping your refrigerator cold, you might want to check the temperature settings. The refrigerator should be set at around 37-40 degrees Fahrenheit. If the temperature is too low or too high, your food won't stay cold enough. https://refrigeratorshouse.com/best-33-inch-refrigerator/
