Hi there,
I'm trying to create items using the iOS Developer guide. I can create items setting only the Text Fields, but if I try and set any others, I get errors
Do you have any examples for setting the following field types:
For lookup fields I am getting the error "Invalid lookup value"
What should the format be - I am using the following code without success
var attributesDictionary = {
'TempLookup' : "3;#Beta",'Title': "Testing"};
Cheers,
Nick
Hello Nick,
Would you mind asking this to Tisho in your call then post the results here?
Thanks in advance,
