20
French accents affecting SharePlus
We currently use SharePoint software, and we use Shareplus to view the documents on the iPad. However, when we import document with French accents, the document name can have French accents, but when we enter the Metadata and in the "Name" convention we input any French accents (é) those documents don't synchronize with Shareplus, soon as we remove any special accents, the file then becomes available on Shareplus. Is there a way to be able to retain the French accents and also have the documents sync or is this a limitation of Shareplus? thank you
  • 9505
    Jamal,
    Because I couldn’t reproduce the issue on my end with the latest version, I sent two new app builds for you to test and try to reproduce. As per case CAS-185008-V3T4J5, it looks like updating to the latest version of SharPlus fixed the issue.
    Regards
