We are using SharePlus for field users with iPads working on construction sites. They are accessing custom lists and uploading reports. Normally, if we access these SharePoint lists on a PC, the upload form will show the column description (from the site column definition) after each input field, where it serves as instructions for the user about that particular field. In SharePlus on IOS, it just shows the column name in each input field, rather than using the column description. Is there any way to get the column descriptions to display on the upload forms in SharePlus?
Thanks & Regards, Ellen Dickson
Hello Ellen,
Thank you for your post.
This isn't supported for the time being, though it has been requested quite a few times already.
The only short-term solution would be to implement InfoPath forms in order to have a more customised and intuitive experience for your users.
I hope this helps answering your question.
Thanks for your answer, Javier. I was afraid that would be the answer. I hope Infragistics will figure out how to add this feature to SharePlus soon. Regards, Ellen
Thanks for your comments. Your answer is really helpful for me.
This has been resolved on previous versions. Check our latest, 4.16.1 in which this fix is already in place. mapquest directions
