I'm investigating the possibilities to use different developer techniques to customize forms in SharePoint in combination with SharePlus.
Is there any documentation regarding developing solutions in SharePoint which are compatible with SharePlus ( for example jslink, Infopath forms for View/Edit, spfx)?
Regards // Henrik Andersson
Hello Henrik,
Thank you for contacting Infragistics!You can see the "SharePlus Enterprise Features" section in our help module here: https://www.infragistics.com/help/shareplus/shareplus-enterprise-featuresOur developer guide is also available, here: https://www.infragistics.com/help/shareplus-dev/Please let me know if you have further questions.Regards
Gonzalo Totorica Associate Support Specialist +1 (609) 448 2000 ext 1277 Enterprise Mobility | Infragistics, Inc.
I would recommend you to add the list as a favorite if you haven't already done so, once you have the quick access there, you can just tap the plus (+) button in order to add a new item to it. | Concrete Driveways
