Since the last update I have lost the use of my Bluetooth keyboards arrow keys. Also when filling out and moving between different ‘data fields’ my space bar does not space but opens up drop down list used to change fonts, underline, etc. I have to back tab to the correct ‘box’ then space bar to be able to type and use the space bar appropriately. The tab also doesn’t tab to the next item but highlights areas while typing keeps entering in the same field.
Hi Allen,
Thank you for your support request!
Let me tell you that we identified this problem as related to the use of the UIWebView control. Apple has advised that no new apps with it can be on the market, however apps that have it still can do so up until December.
That been said, we will work on providing a new version of SharePlus both Enterprise and AppStore versions that use instead the replacement control, the WKWebView which fixes these issues.
Let me keep you posted as news develop on this matter.
Kind regards,
Adrián PévereSenior Support Specialist+1 (609) 448 2000 ext 1262Enterprise Mobility | Infragistics, Inc.
Thank you, a few users in my office are running into this since a previous update.
Hi Allen!
I would like to ask you for your help on this. Could you please insert a screenshot or a video of this behavior here? We are trying to determine actually the type of frame and forms that are been used to narrow down the usage and cases.
Thanks!
Adrián.
I hope you are doing well.
This is to let yoiu know that we have released SharePlus version 4.15.15 which addresses the problems related to bluetooth keyboards linked to the deprecated controls.
You can access the AppStore directly from this link.
Let me know if you find any issues with it.
Adrián Pévere
