I would like to get your advice as I have sign up SharePointPlus for iphone. But unfortunately I’m not able to view most of the data and document on my SharePoint.
1. Could you please advise that what’s the reason will caused we not able to view all the information?
2. We are also not able to access calendar, announcement, document library and etc.
3. Does SharePointPlus provide mobile view? Do the customization is limitation? Appreciate you can list out the limitation for further knowledge.
Hi seuktenk,
Thank you for posting at IG forums!
Can you at least connect to your site?
If yes, do you see just part of the content and not all of it? Is it lists/libraries only? Subsites only? A mix of the two?
Can you see the missing content if you browse the site in Safari using the same credentials?
Do you get any error messages?
What do you mean by mobile view? What customization are you talking about?
Which part exactly is failing while distributing with Airwatch?
What version of SharePlus you are using?
Jumpstart Service
Using a mobile device, you can choose between two types of views. Mobile view and desktop view dumb ways to die
For some types of SharePoint sites and OneDrive libraries for work or school. In PC view, users will see navigation links on top. In the mobile view, users will see the website formatted to look good on their devices.
