20
Checkout docs
Good evening,
I am fairly new to SharePlus, and would like to understand how the Checkout works on an iOS device.  Where are the documents checked out to.  I have quickoffice pro and docs to go pro on the device.    Also in terms of check in, uploading the document where is the local drive to select the document from.
thank you
  • 9735
    Hi helsawaf,
    Thank you for posting at IG forums!
    The Check Out action does not "save" the document to any place. Checking out a document grants you its full ownership until you check it in. This is SharePoint's behavior and SharePlus respects it.
    Once you've checked out your document you may edit it in QuickOffice as shown in this video.
    After the document is updated (you've saved back from QuickOffice and confirmed in SharePlus) you may check it in so others can edit it.
    Does this answer your question?
    Best regards,
