Hi, I used the free version of Sharplus for a day and then purchased the Pro version.
In the free version, I can see all my 365 sub sites fine, but in the Pro version, they do not appear. I have checked all the settings and they appear to be ok,
What should I try next?
Thanks in advance
Jits
Hi Jitandra,
According to your last message via our support system SharePlus is working as expected now.
The issue was probably a cache issue (which probably refreshed itself after a couple of login attempts).
Now that everything is OK, is there anything else I can do for you?
When I have such problems, I clear the cache at the beginning, and then I delete and reinstall it if this application. This solves 80% of all problems.
