Two questions;
1) I have an infoPath form that works pretty will on the iPad (a little jumpy and see question #2) but the same form does not work on my iPhone. The form will open up but once I select a field (date picker, drop down list, text fields, etc) the form screen goes blank, or some of the form is missing (see attached pics) but the form ribbon is still there. It will also not load data into the form from a list data connection.
2) Same form. On the iPad, when I add a new form I get the "Save" & "Save As" options in the form upper ribbon. But when I open an existing form the "Save" & "Save As" options are gone.
pics
Hi ARedWolf,
Thank you for posting at IG forums!
SharePlus provides limited support for InfoPath forms.
Are you running the same version of SharePlus in both devices? Do they have the same iOS version?
Do any of the mentioned issues happen in Safari?
Looking forward to hearing from you,
Unfortunately in order to the lookup field to work the list has to be synchronized first, what happens is that while offline the App is keeping the changes in the draft state and commit them to the server once synchronization is done.
____________
Long Distance Moving
When I read an article on a terrific game like this, it's wonderful. If you can territorial io understand that, it is really cleverly written. This is a fun game that makes us feel many different things.
2. The "Save" and "Save As" options are likely not appearing when you open an existing form because the form has been set to read-only mode. In this mode, the form is only intended for viewing and can not be edited or saved. You can check the form's settings or permissions geometry dash lite to see if it has been set to read-only mode and make changes accordingly.
