60
HTTP Redirects - E.g. http:// to https://
We (as I’m sure many others do) have different addresses for internal and external access to SharePoint. We run into problems when users needs to configure two sites (one for internal use and one for external use).  In our case we only changes http to https between internal and external usages, but I'm sure that other companies have different approach. I understand that there might be different approach depending on what status code is used. In our case we use status code 302, but could change that it you support other redirects
Support for redirects could also be usefull when doing redirects due to service etc.
If others also experience the same problems, please reply on this post
