Hi Patrick,
Thank you for posting at IG forums!
You can edit a blog post from within SharePlus.
I added a new post:
Tap the arrow to the right >
Here you would see the post's replies. Tap the arrow to the right >
Tap the actions button then tap Edit Item:
Once you're done, tap the Save button (Save As Draft will be available in v3.5 around September 9th):
I could not reproduce the issue with adding a reply to the post:
Does it happen all the time to you?
Hi Javier,
Thanks for your response!
After your third step you see a + in the upper right corner of your screen. When I use this to add a comment to a blog entry I get the screen posted in my
Is there any other way to reply to a blog post?
Would you like to check with this particular document in case it’s that and let us know how it goes? | concrete driveway
