While using SharePlus PRO, when I try to connect to a SharePoint site (which has been successful in the past) the 'loading' message appears and just spins.
When I try to test the connection (forms-based), I received this error:
"Authentication Fails
Service response in unexpected format, please review your configuration."
Using SharePlus Pro v3.5.40 on IOS 6.
HELP!!!
I am also having a problem connecting to folders on a site. When I click on a document library in the left-hand navigation, the "loading" box just spins and data is not returned.
After corresponding with Javier, this item will be resolved in a future release.
Thank you for your support Javier....you have been very helpful!
-Steve
All you can do is view a few items on a particular list.
Semi Truck Engine Repair
