Hi, I'd like to ask whether it is somehow possible to log out of SharePlus?
I'm using the Web Login and my login survives even application restart
Hi Marcin,
Thank you for posting at IG forums!
Please tap and hold the site's name in the home screen then select Clear Credentials Cache and confirm. This will delete all session cookies and will force SharePlus to ask for credentials the next time you want to access the site.
Best regards,
Do you need different views for the same list? If not then you may set their particular view as the default view and mark the lists as favorites in SharePlus. | concrete driveway
