I am trying to get InfoPath working with Shareplus. It is mentioned all over that there is "limited infopath support". I am happy with that. All I want to is to be able to view an XML file that is stored online. When I try to do this, I get an error message "The following location is not accessible, because it is in a different site collection: [followed by the url of the xml file].
I am not sure if this is a SharePlus issue or SharePoint.
Any help would be appreciated.
Hi Matt,
Thank you for posting at IG forums!
You say InfoPath forms then you refer to XML files. InfoPath support is limited to Forms Libraries and InfoPath forms for sites that have Form Services enabled. An XML file for a form isn't a form (in SharePoint) just by having the XML extension.
Having said this, can you access the same form in Safari? Does the URL you get have the same domain as the URL you used to set up the site?
Looking forward to hearing from you,
I may be confused here, so bear with me.
Infopath designer creates a file with the extension .xsn I created the form and then sent it to a new sharepoint library. We are successfully using the library via a PC. A user goes to the library, clicks Add Document and fills in the form, then saves it. The saved file in the library has an .xml extension. I want to be able to navigate to the library and open a file and read it on my ipad using shareplus.
Yes I can view files in Safari.
Sorry, I don't have my iPad with me to check the URL question.
Matt,
Do the items in your library (in SharePlus) have this icon?
InfoPath forms do have an .XML extension but what I tried to say is that simply uploading the .XML file created with InfoPath designer to SharePoint doesn't do the trick.
Since you state that when you click Add Document, the resulting is an .XML file, I assume you're dealing with a Forms Library. When you browse this library in SharePlus, the actions button, does it say "Add Form"?
If all of this is present (icon and add form) then we'd need to verify the URLs.
Please follow the steps in this post to enable and send us the technical logs after reproducing the issue a couple of times: http://www.infragistics.com/community/forums/t/73340.aspx
I now have my iPad handy and I can do somre more testing. I agree it seems to be a URL issue. I can confirm that
Here are the log files and also a brief video.
http://dl.dropbox.com/u/30711565/SharePlus.zip
Matt
