1. The lookup limitation issue- one of the issue in sharepoint form libraries is the lookup issue when lookup columns in a view is more than 8 lookup columns. There are 2 ways to solve this, the first one is to adjust the throttle service in central admin. The second one is to maintain equal or less than 8 lookup columns in a view( lookup columns are lookup type, person or group type and workflow column name). We were able to solve this by following the second solution. However, in shareplus, when we try to access the same form libraries, we still get this error compared in viewing it on a browser( safari or native shareplus browser). My theory here is that when shareplus pulls data from the library, it automatically pulls all the columns/fields inside that library, making the view with less than 8 lookup columns useless. Even if it renders the correct filtering (defined in the view) it still throws this server error.
2. Attachment in infopath browser based forms. - as you know shareplus has a capability to store documents inside shareplus app "local files". User can use this file to upload it in sharepoint libraries. In this way, shareplus wa able to eliminate apple's restriction in file browsing. However, when an infopath form is opened inside the native browser of shareplus, we cannot attach a file from the local files of shareplus. We can only attach either existing pictures or a new picture. the default shareplus browser doesn't inherit the capability of the local files saving feature.
Egumball reviews were a real find for me. I was looking for a way to improve my business's visibility online, and the reviews of this service helped me make the right decision. They showed how Egumball successfully increases companies' rankings in search engines, which allowed them to attract more customers. The reviews also noted the team's professionalism and their willingness to help at every stage. Now I see the results - the flow of customers has increased, and my business is growing thanks to effective online optimization.
Hi Jayargozon,
Thank you for posting at IG forums!
The issue with lookups and SharePlus can't be avoided since the web service that is required to know the columns of a list doesn't just ask for the columns of a particular view. The entire collection of columns is returned (even hidden and internal columns). This is necessary to determine the structure of the list (imagine you wanted to add a new item, you'd need to know all of the columns).
To sum up, because SharePlus uses web services and needs to know the structure of the list, this issue can't be avoided.
The issue with InfoPath forms: you're using them via a web view (an embedded browser) and it has the same limitations as Safari. No workaround for this either.
For now, we're not addressing these issues so I couldn't say the fixes will be released soon.
Does this answer your questions?
