Local copies of documents from a synced document library can only be opened in read-only mode. I read another post where this was supposedly fixed with a Mountain Lion update, however I am on the latest version of both Office 2011 (14.3.6) and OS X (10.8.4) but am still experiencing the issue. Anyone else have this same problem?
Thank you
Hello Dirk,
Thank you for posting at IG forums!
Does this library require check out to edit? Also, could the document be checked out to another user when you open them?
Does this issue happen with just one library or just any library?
Looking forward to hearing from you,
Has anyone been able to fix this? I am on OS X 10.8.5 and have SharePlus 2.5.06.
My "Local Documents" get checked out read-only.
Jeff
Are there any fixes for this yet? Having to save as a new filename is not acceptable. This is the reason I purchased the Pro version and it's pretty useless without this functionality.
Neil
