Hey folks,
we are using MS SharePoint 2010 on a Win 2008 R2 server behind MS Forefront TMG 2010.
Configuration:- Connection is SSL encrypted (valid certificate)- Mode in SharePlus is "Web Login"
The authentification window is popping up with the login mask of Forefront TMG. After the succeeded login the window isn't closing. Instead the SharePoint site is showing up within the window. So the authentification is working, but SharePlus doesn't recognize it.
Do we have to reconfigure the Forefront TMG for SharePlus or do we have to use another authentification mode? (All other modes doesn't work either at the moment).
Thanks for help and regardsVolker
Volker,
Thanks for posting!
Please try changing SharePlus' user agent to "SharePlus" (Settings>Advanced Settings>User Agent) then select Windows Authentication as the authentication mode.
Did this work?
Looking forward to hearing from you,
Hi Javier,I am afraid it did not. I get the following error message back:
"Service-Antwort in unerwarteten Format, bitte überprüfen Sie Ihre Konfiguration. StackTrace:( 0 SharePlus 0x002ec833 _ZN6PoDoFo7PdfNameC2Ev + 340474 1 SharePlus 0x002ed5a7 _ZN6PoDoFo7PdfNameC2Ev + 343918 2 SharePlus 0x002ede75 _ZN6PoDoFo7PdfNameC2Ev + 346172 3 SharePlus 0x002ee4bd _ZN6PoDoFo7PdfNameC2Ev + 347780 4 SharePlus 0x0047979b _ZN6PoDoFo7PdfNameC2Ev + 1966434 5 Foundation 0x332b40f5 <redacted> + 460 6 CoreFoundation 0x32972683 <redacted> + 14 7 CoreFoundation 0x32971ee9 <redacted> + 212 8 CoreFoundation 0x32970cb7 <redacted> + 646 9 CoreFoundation 0x328e3ebd CFRunLoopRunSpecific + 356 10 CoreFoundation 0x328e3d49 CFRunLoopRunInMode + 104 11 GraphicsServices 0x3649a2eb GSEventRunModal + 74 12 UIKit 0x347f9301 UIApplicationMain + 1120 13 SharePlus 0x0000393d SharePlus + 10557 14 SharePlus 0x00003890 SharePlus + 10384)"
"Service-Antwort in unerwarteten Format, bitte überprüfen Sie Ihre Konfiguration."Translation: "Service replay in unexpected format, please check your configuration."
Thanks for helping!
Volker
*reply
What was the solution to this issue? I am experiencing the same issue.
Thank you in advance for your assistance.
harePoint Database Recovery tool to effectively recover all data items from corrupt MDF database. The software is works on all MS SharePoint server and compatible with all MS SQL Server. automobile glass repair
