We are having a problem with the PDF viewer on the iPad. The PDF contains bookmarks that are written in swedish, and the swedish characters (å. ä, ö) appear incorrect when the Bookmarks list is opened when viewing the PDF.
Does anyone have the same problem in another language? Anyone has a solution, or heard if this problem or similiar will be solved?
David
Hello David,
Thank you for posting at IG forums!
Would you mind send us a screenshot and an example document?
The document can be just an example to reproduce the issue, it doesn't need to be a real document.
Looking forward to hearing from you,
Hi Sebastian,
if you look at the picture, the yellow markers should be replaced by å, ä and ö which are letters in the swedish alphabet. As you can see, they turn into other erronous characters.
Hope this guides you to identify what's the problem.
FYI: The pdf bookmarks look fine when viewed in other PDF viewers.
Thank you so much for your help!
/David
As it is, this is pretty much a no-go, so I would like to know if improvements on this front are to be expected soon(-ish)? Arborists
