We upgraded our test environment to have claims authentication. So our web application is set to have both forms authentication and windows authentication. Trying to connect to a test URL via shareplus gives us an error. The error is a "Server Message: Server was unable to process request. ----> Access is denied. (Exception from HRESULT: 9x80070005(E_ACCESSDENIED)))
Is there something we need to setup special to get this to work?
Scott
SharePlus supports Claims based authentication through Web Login, which needs to be selected in order to connect to your site successfully.
SharePlus needs the certificate in Local Files. You may access them by syncing your iPad with iTunes then going to Applications > File Sharing and clicking in SharePlus Lite. You may add your certificate there. Commercial Kitchen Cleanings
Claims-authentication is an upgrade that you can do in your WordPress website to improve the security of your site. With it, you can verify the identity of people signing up to your website posterdle before they are given access to it. The most common type of flagle claims authentication is email verification.
Most passwords are verified via email. That forces you to keep a good record of your email. All information will be directed towards it Madalin Stunt Cars.
A concept map is a teaching and learning strategy that bridges the gap between learning styles and learning goals. Concept maps in nursing are used to integrate theory and practice, case management, and as a teaching tool for nursing students.
