I want to access with Shareplus to a Sharepoint portal hosted in port number 7090, and using SSL.
So the URL is: https://mysharepointportal.domain.com:7090
Is Shareplus compatible with port numbers different than standard ones???
Hello Angel,
Thank you for your support request!
Yes, you can add the port number. This should work without issues.
If you can't make it work, please update the thread and we'll troubleshoot the issue.
The values in the lookup field come from another list. In this new version, when I click on the Lookup field to select a value, the entire thing is blank. No values show. Synthetic Turf Installation
