We use SharePoint internally and were looking for a solution using SharePlus to automatically sync a document library that would be updated.
This would need to be available without any signal.
I have been testing this and managed to select offline Support and Background Sync which is great but as soon as I go to airplane mode to test it offline I run into some issues.
With Airplane mode enabled I enter the SharePlus app and select the relevant SharePoint site from the list. I then get a connection error (as I am no longer connected) which I cannot bypass to my offline library. I cant seem to enable the entire site offline so I wasn't quite sure how offline more is meant to function.
I know the alternative is local files but it would be good to simply enable a entire library or even site into offline mode so documents can be access and when on WIFI this is automatically updated.
Any assistance would be much appreciated.
Managed to find the solution, missed the offline button!
I'm glad you found it. Let us know if you have further questions.
I have the same problem but am obviously not as advanced as the previous user as I cannot find the offline button he refers to. We use Sharepoint at work (a university) and Sharepoint sites are set up for each department - my department has three separate sites which I have full administrative rights for. Most people run Windows machines so can have an offline copy using SkydrivePro. I run a Mac and was advised to use SharePlus for the same purpose (I don't think anyone else in the university has done this yet).
I have just downloaded it and set up the three Sharepoint sites on SharePlus. I have just figured out how to view or edit a file (right click when on the file icon - not that obvious and no help menu) but that only works when I am online. How do I get my Sharepoint sites stored locally and synchronising when I am online? I cannot find any menu items that even vaguely look helpful.
Can you at least connect to your site?
If yes, do you see just part of the content and not all of it? Is it lists/libraries only? Subsites only? A mix of the two? concrete driveway contractor
Fleet maintenance is the process of ensuring that all of the vehicles and other equipment belonging to your own business are in good working condition from a mechanical point of view. This process ensures that your fleet continues to be easily maintained for use by other companies who may be looking for it. fleet repair services Tallaght
