We have a brand new enterprise deployment and I'm struggling with our remote configuration file.
The app should be configured to use a file called "SharePlus_Config.plist," hosted in the siteassets library of the root site collection on our SharePoint server. I have defined a web dashboard as below, but the enterprise app isn't showing me the dashboard. So, I have two questions:
WebDashboard configuration:
<key>WebDashboard</key> <dict> <key>Enabled</key> <true /> <key>Settings</key> <dict> <key>BridgeEnabled</key> <true /> <key>DashboardSourceType</key> <integer>0</integer> <key>DashboardSource</key> <string>http://connect.moog.com/communities/1468/siteassets/html/test_splus.html</string> <key>Title</key> <string>Moog SMM</string> </dict> </dict>
Hello Adam,
Thank you for contacting Infragistics.
Adam Wolff said: Can SharePlus read the plist from a SharePoint site requiring authentication, or do we need to host it someplace else?
Yes, SharePlus can read the configuration file from a place that requires authentication, but it will prompt for credentials every time it needs to read the file.
Adam Wolff said: Does SharePlus read the plist every time it loads? Or if not, how do I ensure that it's looking at the most recent configuration?
Yes, SharePlus does read the configuration file every time it loads.
If you love shooting action games, then Cuphead is a definite game you should try at least once. I am sure you will like it.
