After the app update, I had to re-enter the Domain name to successfully test the login account. (I am using Forms-based Authentication and SharePoint 2007 on SharePlus v 4.0.2)
I then received an error when I tried to access a folder in a SharePoint site. When I go to a site and attempt to enter a folder, I receive an error "Service Response in unexpected format, please review your configuration". I sent the report error with the stack trace details and I have a few case numbers.
If I close and re-open the app, I am occasionally able to successfully access the site and documents. It is inconsistent...sometimes I can access the site/folders and other times I cannot.
Thank you in advance for your assistance.
Thank you for reporting this issue. We recently submitted another patch to Apple that addresses a few service and security features within SharePlus 4.0. At this time I do not have an ETA when the next AppStore update will be available but rest assure that we are always making improvements to our applications. I recommend waiting for that release and if you are experiencing the same behavior you can reply here again.
Thank you for the prompt response. I will look for the AppStore update.
