When setting up a collegues iPad I received this message, “SharePoint document failed to download. (Error: URL Error)”. I set up antoher collegues iPad and I was fine, no error. What does this erro code mean?
Hello Shawn,
Thank you for reporting this behavior. May I ask if you can clarify when this message is displayed? This message is unfamilar to me and sounds like it would be the result if a user attempted to obtain an item from a SharePoint server when they were offline, aka airplane mode.
Which version of SharePlus are you using? Has the device that reproduces the behavior configured SharePlus successfully and now is attempting to perform some action with the content displayed?
To troubleshoot this further I require technical logs produced from SharePlus. Please follow steps here, after reproducing the issue a few times.
http://www.infragistics.com/community/forums/t/73340.aspxIf needed I can open a case to continue this conversataion privately. Thanks again.
SharePoint software which is associated with intranet, document management and with content management. But you may get some error and there are numerous reasons for that error. However to repair that error, you should use recovery software like SharePoint repair tool as this repair tool will repair the error of SharePoint and you can recover the corrupt or damaged data without any data loss. This repair tool can be used by any one and does not require any technical knowledge.
Corrupted SharePoint database due to drive failures, accidental file deletion on WSS websites, drive failures, server downtime, saved backup turned bad, and any other, then I would like to refer user-friendly tool :- http://www.filesrecoverytool.com/sharepoint-database-repair.html
If your SharePoint Server becomes corrupt/damage or inaccessible then, there is a need to repair SharePoint database. To execute this process try expert:- http://www.recoverydeletedfiles.com/sharepoint-server-data-recovery.html
Microsoft Office SharePoint Server (MOSS) is also called as SharePoint is server software which is associated with intranet, document management and with content management. But it becomes corrupt due to several reasons and therefore use Sharepoint Recovery Tool software which can easily repair the corrupt SharePoint file.It is basically used for hosting website, content database, list, documents, list, libraries etc. As computer applications get damaged, so there is no escape of Sharepoint as well. Read more: http://www.softmagnat.com/sharepoint-recovery.html
