I created a new Default NewForm.aspx for a SharePoint list. Reason being I did not want all the fields completed when it was a new list item. When I add a new list item through the browser it uses the correct form. When using shareplus it is not the correct form.
Hello Natalino,
Thank you for contacting us today. I created a private case to continue our discussion. The case number is CAS-143178-V3T7D0. You will see it located here: https://www.infragistics.com/my-account/support-activity
I have the same problem. Do you have the solution?
If you own an online store, then I advise you to read this post, because it can be useful to you. There are times when you need to move to another platform on which to base your store. And to make it easier for you, you can use bigcommerce to woocommerce . This service will be able to help you to switch automatically
