I get the following error when trying to connect to any site.
Certificate ErrorSharePlus can't validate your server's certificate to ensure a secure channel. Please contact your IT Helpdesk for assistance.
I have no issues connecting via a browser and see no certificate errors that you would expect to see receiving an error like this. I can also connect fine from my mobile browser.
Running the latest android on an S6Sharepoint is a 2013 environment using then web application proxy to publish the site external.Example Site URL: https://share.domain.com/sites/community/sitename
Hello Andrew,
The Certificate Error means that your security certificate is not trusted or has expired, and the connection can't be verified to be private.Your SharePoint site's identity might not be confirmed and SharePlus for Android is not able to access it securely through the HTTPS protocol.
I just talked to our Engineers about this and told them that you don't see certificate errors in your browser as expected.They want to review your issue, so please reproduce the issue and, when prompted, report the error so we can receive the stack trace.
Juan Pablo AyalaEnterprise Mobility TeamInfragistics, Inc.
I'm writing to you in order to check if you're still experiencing issues accessing your server.
Were you able to check the security certificate needed for the connection to be authorized?If so, do you still have issues with SharePlus?
Please let us know
Regards
Gonzalo T Technical Support Engineer I Enterprise Mobility Infragistics, Inc.
Hello Andrew
I'm writing to you in order to check if you have further questions.
I will keep this case open for another three days while I wait for your response. It'd be great for other users for you to publish the solution.If at that time you haven't responded, I will close this case as inactive. Please note that closed cases may be reopened within thirty days of closure.
Best regards.
Gonzalo TTechnical Support Engineer IEnterprise MobilityInfragistics, Inc.
I will keep this case open for another three days while I wait for your response. If at that time you haven't responded, I will close this case as inactive. Please note that closed cases may be reopened within thirty days of closure.
Gonzalo T Associate Support Specialist Enterprise Mobility Infragistics, Inc.
Please tap and hold the site's name in the home screen then select Clear Credentials Cache and confirm. | concrete driveway contractor
