Are you aware of any aftermarket products or components within SharePlus that would let me digitally sign a document. I am using SharePlus to interact with my SharePoint online sites and often times need to digitally sign a document. Please advise.
Hello Stephen,
You can use the "Open In" function in SharePlus in order to open the file you want to digitally sign.This will open the file in any app you have installed in your device, after you sign the document, you should be able to "open in" the document from the signing app, back to SharePlus.
I can recommend you to check this article about apps that allow users to digitally sign their documents: http://www.macworld.com/article/2888459/5-apps-for-signing-documents-with-your-iphone-and-ipad.html
Please let us know if you have further questions.
Gonzalo T Associate Support Specialist Enterprise Mobility Infragistics, Inc.
I'm writing to you in order to check if you have further questions.
I will keep this case open for another three days while I wait for your response. If at that time you haven't responded, I will close this case as inactive. Please note that closed cases may be reopened within thirty days of closure.
Best regards.
Hello Stephen, If you re facing trouble with your digital signature, visit here: https://vakilsearch.com/digital-signature. Vakilsearch is one off the authorised digital signature providers.
Digital Signatures are a form of electronic signatures – both are used for document signing – but there are a few important features that make them unique.
I need a digital signature to use for online transaction records processing. Refer io games build royale
