20
Object reference not set to an instance of an object
I'm new to this so sorry if I ask a basic question.
I'm using
UFT version 12.52
Infragistics Windows Form Test Automation for HP Unified Functional Test Software 2017.0
I need to select a checkbox in the first column and first row of a UltraWinGrid.UltraGrid
I'm using following to automate a test script
 SwfWindow("XXX Xuite.NET: XXXX Tool").SwfTable("SwfTable").SetCellData"0","mCheckBox"True
I get 'Object reference not set to an instance of an object' error.
Can you please assist.
Parents
No Data
Reply
  • 21795
    Hello Usman,
    You are on the right path. To check the check box put the value you are passing, True in this case, in quotes like this:
    [code]SwfWindow("XXX Xuite.NET: XXXX Tool").SwfTable("SwfTable").SetCellData"0","mCheckBox", "True"[/code]
    Nice place to see what the correct syntax is is by recording scripts in UFT. There are several samples provided with Infragistics TestAutomation installation you can play with. More information about these sample you may find in our online help here “Accessing the Samples”.
    Please let me know if any additional questions on this matter arise.
Children
No Data
