40
TestAdvantage for Windows Forms (IBM) 2008Vol3 CLR 20
I am developing automated tests whit Rational Functional Tester 8.0 for an application
built in .NET, specifically with C#. However, I have a problem with this application
because it uses a third party software component named “Ultragrid” provided by you
(Infragistics):
The trouble occurs when I add a verification point in the script, RFT doesn’t recognize
 the component, and it can´t obtain all the properties and values of the control.
 I installed the Trial version of the Infragistics proxy TestAdvantage for Windows Forms
 (IBM) 2008 Vol. 3 CLR 2.0 and I created a Rational Functional Testes script  and it
 was able to get  the value of a cell, but RFT still doesn't recognize all properties of
Infragistics object control because now RFT doesn't indentify a click  on the object:
 Can someone help me with this problem?
Thank you in advance,
ISC. Arely Nava Anaya
