20
How to Integrate TestAdvantage for Windows Forms (IBM) 2008 Vol. 3 CLR 2.0 with RFT 8.0
I have installed RFT 8.0 and TestAdvantage for Windows Forms (IBM) 2008 Vol. 3 CLR 2.0 - both have valid licenses.
How do I integrate Integrate TestAdvantage for Windows Forms (IBM) 2008 Vol. 3 CLR 2.0 with RFT 8.0?
Somehow RFT doesn't seem to recogonize the infragistics control names used in my sample script.
It would be of great help if someone could throw some light on my above situation.
Thanks in advance!!
Anand
  • 6729
    Suggested Answer
    Hi Anand,
    Are you trying to script in VS 2003? if so then that is the reason. TestAdvantage 8.3 is only compatiple with VS 2005.
    if you are using VS2005 or Eclipse then there might be some configuration issue, Try playing back the samples script shiped with TestAdvantage.
    Let me know how does that go
    Ammar
