I am using an infragistics application where my application version is 7.1.20071.40(.dll files version).
So, i need to install the plugin Test Advantage 2007 Volume 1.
So, I installed it.But when I open, the .dll files version is not matching with my application .dll files.
Application .dll files version: 7.1.20071.40
TestAdvantage .dll files version: 7.1.20071.1006
And i am not able to highlight any objects in my application.
Will it be the above reason?..If so, wat steps i need to take care?,
RFT version:8.0.2
I also tested the sample application which comes up with Test Advantage 2007.
But my application is not working.
Kindly help me.
Chandu.V
Hi Chandu,
The file versions between NetAdvantage and TestAdvantage only needs to match the first 3 parts (i.e. "7.1.20071.") as the last part is a revision number and does not have to match.
I understand from your post that recording and replaying on the TestAdvantage application worked fine but not on your application, please confirm.
If this is the case then maybe the CLR version of the application and TestAdvantage does not match.
TestAdvantage 2007 Volume 1 was shipped with CLR1 and CLR2 versions of the assemblies. What is one of the file names of NetAdvantage assemblies and TestAdvantage assemblies? Both have to start with the same first part (i.e. both should start with "Infragistics." or "Infragistics2.")
You can use the version utility of TestAdvantage (from the Start Menu) to switch between CLR1 and CLR2 assemblies.
Let me know what you get.
Ammar
thanks for ur response.
With TestAdvantage application got worked successfully.
But in my application its not able to highlighting any objects.
My NetAdvantage assemblies do starts with Infragistics2. So, i shipped to CLR2 version while selecting the version utility.
But still I am not able to highlight any of the objects.
Could you please help me?
Is there any case where i need to include the proxies(infragistics) inside customization.rftcust file?
You don't need to add anything to customization.rftcust file. All Infragistics mapping are included in Infragistics2.rftcust file. Since working on the sample worked then TestAdvantage is configured properly. Usually this issue appears if the test application is using a different version of NetAdvantage.
Use Process explorer to check the loaded assemblies in your application and make sure they are 7.2 CLR2
Also what is the control that is failing to highlight? If you try to record actions in your application what do you get?
Thanks for your quick response.
I checked it with process explorer.
Then i found that, from the customization folders(IBM) only 3 .dll files are been loaded with 7.1 CLR2 version..
As the NetAdvantage version is 7.1.20071.40..They are:
C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization\Infragistics2.RFT.Win.v7.1.dll
C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization\Infragistics2.RFT.Shared.v7.1.dll
C:\Documents and Settings\All Users\Application Data\IBM\RFT\customization\Infragistics2.RFT.UltraWinToolbars.v7.1.dll
Even the Infragistics2.RFT.JavaTestObjects.v7.1.jar is also loaded.
And from my application i found that all the .dll files are been loaded.
I am not able to record any actions in my application.
Could you please cross-check whether am i using the correct version of TestAdvantage?
I am also sending the .dll files which goes with my application.Attached are the .dll files in my application?
Attached is the screenshot for the customisation folder, and two files(rftcust and rftop files).
