Currently we are using the "Infragistics TestAdvantage 11.2.0 x86 " and now we installed this version ,installed "Test Advantage 2015.2".
After this we are facing issue in UFT Code which is running on old TestAdvantage 11.2.
Error we observed that is "IG : The IG TestAutomation assembly is not versioned, but the AUT's IG Control assembly is."
Any help is highly appreciated.
Karthik
Hello Karthik,
Thank you for contacting us.
I have been looking into your post and I have a question for you.
Are you using the TestAdvantage for WindowsForm or the TestAdvantage for WPF?
Our issue got resolved, we are using WindowsForm.
Thanks.
Thank you for the feedback. I am glad, that you have found a solution to your issue.
Can you share what you did for the fix? I am having the same problem.
Primary cause of this exception is you are using the wrong version of IG TestAutomation for the controls that you are testing with. Follow the steps here and let me know if that helps.https://www.youtube.com/watch?v=j-_dQHVSt2U&t=13m21s
