20
Installation Of Windows form Test automation plug-in in UFT-12.02 version
We have the trial version , but we are unable to view that on add-ins screen. Please advice how to install that to UFT. It would be helpful ,if you could share the steps in details.
Thanks.
  • 6120
     Hello Manvi,
    Thank you for posting on our forums.
    When TestAutomation is installed it will not show up in the UFT add-in screen. You can install TestAutomation for WindowsForms by running the installer and you can verify if the install is successful by implementing the below steps:
    1. Open UFT and check if the objects are being recorded as Click(X,Y). If they are, then install might have failed. In this scenario you would repair/re-install the product.
    2. In the system search window, type VersionUtility and check if it’s available. This is an Infragistics tool that is used to update TA version. It will be added to the system Taskbar when you successfully install TestAutomation.
    Please let me know if I may be of further assistance.
    Sincerely,
    Sahaja Kokkalagadda
    Associate Software Developer
