20
Not able to create a object
Not able to create a Object. Below is the code.
set Rect =Javawindow(Windoname).JavaObject(objectname).CreateObject("java.awt.Rectangle"1020)
Please let me know if these is any error in the code.
Thanks in Advance
  • 26785
    Hello Suma,
    Thank you for contacting Infragistics. Which platform are you testing with UFT?
    Note, Java is not a supported platform. If you are testing Windows Forms application the type name for windows should be SwfWindow. If you are testing a WPF application the type name should be WPFWindow.
    For more details on UFT/Test Advantage help please visit our online documentation at:
    https://www.infragistics.com/support
