hi ,
we are working with HP UFT 12.01
and TestAutomation WinForms HP 20141 ( 2014 01)
our application uses .net 4.0
(in version utility chose CLR 4)
we tried also with Coded UI ( under visual studio 2012) but still same results
using your samples under coded UI it worked fine,
but for our application the UFT still sow events as Click (x,y) and nothing related to controls like Ultra tree or Ultra Grid
our application uses CAB ( smart client ).if it make an issue
can you assist ,
thanks.
Hello Liran,
Thank you for contacting Infragistics. Which version of Infragistics is your application referencing. If it's not the same as 2014 Volume 1 (aka TA's version), then there will be compatibility issues.
Keep in mind that Coded UI and Test Advantage are two completely separate tools for testing an application. They cannot be used in the same way nor are related.
Another note, I recommend recording against the samples that are included with TestAdvantage to ensure your configuration is setup correctly. If you already tried this what were your results?
The samples are located in the following path under Windows XP for the most recent versions of TestAdvantage: eg.
C:\Documents and Settings\All Users\Documents\Infragistics\TestAdvantage for Windows Forms (HP) [version]\Samples
Sample Location: For Windows Vista and Windows 7 this would be: eg.
C:\Users\Public\Public Documents\Infragistics\TestAdvantage for Windows Forms (HP) [version]\Samples
Hi Michael,
thanks for the quick response,
in the application we are using 14.01 (for now)
we have tried the samples but all of them froze during record (not responding)
both under CLR4 and version free ( changed it under Version Utility before opening the UFT)
so now the question is does the version of UFT compatible with 14.01 ( UFT version is 12.01 - that is what we have)
or is it something else you can think of to help us .
Liran
so i download a trial version of HP just to check (14.03 )
it seem to work , so there might be a issue with 12.01 and Infragistics 14.01
issues that we did found were
a problem with editor button that under the test no action was record for selection or clicking the button.
and sometime dialog windows or message boxs that the test did not record property and failed because of that.
again we have HP 12.01 so i rather use that and not update it yet, ( might not be possible)
Thank you for following up. HP UFT 12.1 is compatible with Infragistics 2014 Volume 1, but I have not seen any issues personally with this setup. However I know that HP UFT version 14.1 had terrible results with our controls. Anything newer is preferable, but please keep in mind that we only tested Infragistics 17.1 and later with HP UFT 14.0.
For more details about our supported environments please visit our website at: https://www.infragistics.com/support/supported-environments
well i tested it again on my machine ( the first tests were at the QA env. so i need to check what is installed or not on it)
i got it to work ( with the samples and our application) so it does not freeze.
i still got an issue with editor button ( button in the ButtonRight collection of the cell)
the UFT does not recognize it , do i need to write a code in the action tab in the UFT to simulate a click on it ?
can you give me an example as how to do so ( working with editor button i mean)
