205
SetFilter method “freeze“
Hi
I using QTP 9.2  with TestAdvantage_WinForms_HP_20083_CLR2x
When I run
SwfWindow("").SwfWindow("").SwfTable("").SetFilter "0;Event_ID","(ALL)"
All O.K.
When I using QTP 10 with TestAdvantage_WinForms_HP_20083_CLR2x and run -
All “Freeze”
Any update  that I can install ?
  • 7695
    Suggested Answer
         Short answer, since you are using TestAdvantage 2008 Volume 3, all you should need to do is to apply the latest TestAdvantage service release and it should correct this behavior.
         Long answer, as of the release of QuickTest Professional(QTP) 10 a breaking change was introduced that when we called QTP's internal method to send a string of keys to the application under test(AUT) it caused a thread dead lock. We added a work around for this method in our code to avoid this in the release version of TestAdvantage 2009 Volume 2 forward, and in a service release for TestAdvantage 2008 Volume 2 forward.
         As an FYI, for versions of TestAdvantage\NetAdvantage prior to 2008 Volume 2, it is highly recommended to either upgrade your application to 2008 Volume 2 or later, or downgrade your QTP to prior to 10. If neither of these are viable options, then it is recommend you log a support case and our developer support will try to cater a solution that bests suits your needs based on the controls and actions in question. Below are a list of the actions and controls that were affected.
    I hope this answers your question,
    WinCalculatorDropDown
        Clear
    WinColorPicker
        Clear
    WinComboEditor
        Clear
    WinCurrencyEditor
        Set
        Clear
    WinDateTimeEditor
        Clear
    WinFontNameEditor
        Clear
    WinNumericEditor
        Set
        Clear
    WinTextEditor
        Clear
    WinGauge
        Type
    GridCellProxy
        SetCellValue
    WinGrid
        SetFilter
        SetFilterRowCell
        SetInvalidDataCell
        SetCellData (prior to 7.3)
    WinListView
        EditLabel
    WinMaskedEdit
        Set
        SetInvalid
    WinFormattedTextEditor
        SpellCheck
    WinNavigationBar
        SetLocation
    WinPrintPreviewControl
        KeyPressed
    CalendarCombo
        SetDate
        Clear
    DayView
        AppointmentCreate
        SpellCheck
        ClickToAddAppointment
        SpellCheckNewAppointment
    MonthViewSingle
        AppointmentEdit
        NoteEdit
        SpellCheck
    WeekView
        AppointmentEdit
        NoteEdit
        SpellCheck
    ToolbarsManager
        ShortcutKey
        Set*MaskedTool
        Set*TextBoxTool
        Set*ComboTool
        Set*FontTool
    Tree
        LabelEdit
        DeleteSelected
        SetInvalidDataCell
  • 22852
    Offline posted in reply to Avishai
    You can download the latest service release from the My Keys and Downloads page.  On the TestAdvantage tab you should select your 2008 Volume 3 key.  Once you select the key, you will see the download for the service release in the Service Releases section.
    Let me know if you have any questions with this matter.
    Alan
