We are using QTP 10.00 and in our application we have few infragistics controls, for this I downloaded Test advanatage 2010.1 trial version and tried to install but gettiing some error, may I know which version of Test advantage I need to install and how can I proceed further.
Thanks in advance...
Hi Derek,
I saw your reply for this post. I am aslo facing the same problem in my project with HP Quick Test Professional 10.0 and TestAdvantage.
There are lot of infragistics controls in our application.
I have installed Licensed version of NetAdvantage 2010 Vol 1. I also have Licensed version of TestAdvantage for Windows Forms 2007 V2. But I have downloaded trail version of TestAdvantage 2010 Vol 1 from Infragistics and installed it.
I got to know that I have to run the TestAdvantage version utility, I am not aware of running it. If I have to run it Can you guide me through it? And can you tell me the importance of running it?
I am using QTP 10.0 version
Thank you and Regards,
Sandeep.
The version of TestAdvantage for Windows Forms (for HP QuickTest Professional software) that you download needs to match the version of the Infragistics Windows Forms controls in the application under test.
So for example, if you are using NetAdvantage Windows Forms 2010 Volume 2 controls in your application, then you need to download TestAdvantage for Windows Forms (HP) 2010 Volume 2.
If you need to download a trial version of TestAdvantage for Windows Forms (HP) that is older than the current version (available here), then you can download it from our Archived Downloads page.
