I want to click the link inside cell in grid(Infragistics.Win.UltraWinGrid.UltraGrid) / SWFTable but using the below code i am getting error message Key not found (or) formattedLinkEditor is not defined for the specified cell
SwfWindow(xxxx).SwfWindow(yyyy).SwfTable(zzzzz).OpenLink Row,Column,LinkText,LinkHref
Parameter used:
Row = 1
Column = 3 (0r) FILE_NAME
LinkText = 68662_3006_20120306081832.zip
Link H Ref = http://usvmwelrmd04.amrs.win.ml.com/LRMServer/OutPut/68662_3006_20120306081832.zip
For example :
SwfWindow(xxxx).SwfWindow(yyyy).SwfTable(zzzzz).OpenLink "1","FILE_NAME","68662_3006_20120306081832.zip","http://usvmwelrmd04.amrs.win.ml.com/LRMServer/OutPut/68662_3006_20120306081832.zip"
Please do the needful.
Hello Javeda,
I`m not familar with your scenario, but maybe one possible approach could be if you are using thr LinkClicked of your FormattedLinkEditor. For example:
Set objEditor = SwfWindow(xxxx).SwfWindow(yyyy).SwfTable(zzzzz).GetNAProperty("DisplayLayout.Bands[0].Columns[0].EditorComponent")" objEditor.Object.LinkClicked
Regards
